Sau Vic 2013 Motorsport Championship Round 6 - Sandown Sunday 11Th August
Sau Vic 2013 Motorsport Championship Round 6 - Sandown Sunday August 11th
Hosted by AROCA
Entry Form:
http://sau.loudsx.com/motorsport/AROCA%20Sandown%20EF%2011%20August%202013.doc
Sup regs:
http://sau.loudsx.com/motorsport/AROCA%20SANDOWN%20SPRINT%2011%20August%202013%20Supp%20Regs.pdf
get in quick as it will sell out:
Brought to you by.
current championship results:
http://www.sauvic.com.au/motorsport/2013_ClubChampionship.xls
Much better run...not this year. Easy on par.
Alfa are a slick show however.
It just comes down to schedule. We wanted a break in July and rexy are going to tassie.
get on the E85! you know you want to! :D
You've been reading too much Hypergear thread today :P
Where did you guys email your entries too? I want to get mine in today before the price goes up but I can't find the details?
Send an email to:
[email protected]
Say your from SAU VIC and he'll look after you
Reading through the regs
Do we need to supply our our car number stickers or do we get given them like the WRX days?
Haven't attended an AROCA day before
Also do I need to do anything with these rules?
Headlights, fog lights etc. to be covered by an adhesive film
Be fitted with a return spring on each throttle in the event of the throttle linkage becoming
detached. Fuel injected cars are exempted from this requirement.
Regs sound like number is nominated unless your form states a car number. says you can purchase a number sticker there...
yeah dont worry about the throttle thing.
any forward facing glass (other than windshield) to be covered by tape. A roll of clear packing tape is easiest, or electrical tape for various colours. Or you can ebay headlight film. All will leave a glue residue which comes off with some metho.
Will be spectating, fingers crossed its a dry day.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
