Yeah so... I don't quite own a skyline but the Nissan I own shares a lot of R33 GTR parts.
It's a 1988 Z31 300zx wide body
Converted to a VH45DE infinity V8
GT35 xr6 turbo
Link standalone
R33 GTR brakes
GTR 5 speed
N200 long nose 3.7 LSD diff
GTR bucket seats
Tube & fin IC
Runs on 6 pound of boost and creates approx 420rhp and the car only weighs around 1100kg
It's a pretty hairy ride.
Plans - Motor
Moving up to 550cc E85 compatible injectors
Custom fuel tank & app e85 compatable pump
Increasing the spark (havnt settled on how yet)
Custom log manifold
Possibly twin turboing...
Other loose ends
Move the fuse box and relays into the cabin
Shave the engine bay
Look into running 355/332 brake upgrade and bias valve
Pics to come
https://www.sau.com.au/forums/topic/428874-sleepers-z31-vh45-turbod-300zx/
welcome to the forum mate, keen to see some pics and more info on the car
as mick said 555cc will be on the low side for corn fuel! better of going 1000cc straight out and u never have to worry. Saying that on 420hp already you could easily throw another 10psi into that motor and make plenty on pump gas as it is
  • Like 1
Sounds like an awesome build. What are your plans with the car? Track or street?
As everyone else has said, got straight to 1000cc injectors. 550's will be too small if you plan to take it further.
Hurry up with the pics!
Cheers for the comments.
Car will be used mainly for track. I'd like to stick to pump but I'm worried about pinging and it's comp being 10.1:1 blowing a ring. I havnt been able to find someone or a build with a vh45 going more than 10-12psi so that's why I was leaning to e85.
And yeah wot doesn't Take long before I'm at the servo again lol
The 550cc's are enough for 600, currently I'm on 380's an only 91% duty cycle and without sequential injection (I think that's the right term...)
I simply can't fit 1000's in there... Clearance is an issue to the inlet manifold.
If I do go TT ill be making a ffim where I'll have all the room in the world but for now I'll max out what's there.
I'll see how it holds up on 10-12psi on 100 ron, then look into e85.
600-650 is the plan, anything more simply wont get to the ground.
Also looking into 18x10 18x11.5 rims.
Thanks guys. I'll try uploading a pic of it on boost.
It does sound nice!
Thanks Luke GTR, I don't know how that didn't come up when I searched it... Even on nico forum there isn't any details. Anyway I'll be buying them, now I have to find a set of better coil packs.
Then I should be able to use what I have to easily 5-550rhp :D
Um yes lol
Starter motor relocated to the other side and bell housing welded back up, adapter plate made, custom shifter, ditched the transfer case and made new mounts.
I can't take and not taking credit for the build, my mate built the car and I bought it off him.
First ever car I've bought not built... But it's been done extremely well.
Anyone know of a better coil pack that fits a 45?
And also will there be another bbk group buy???
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
