A few months ago I replied here that it didn't work with my car... I tried it again now I have an aftermarket boost gauge, and I discovered that it actually does work with my car;
- 7 or 8psi without the solenoid earthed,
- 10psi with the solenoid earthed, but...
- when linked to the original loom, I get 8psi till 4500rpm and 12-13psi above the 4500rpm line.
Anybody who knows what might be the case?
It's not boost creep, and I have an elbow-back aftermarket exhaust, stock smic, stock ecu, and a pod filter... so nothing fancy.
Edited by stefan-w
I just did the thing for mt r33 gtst. my one is 93 S I. that was awesome. i hit 10 psi at 5000 rpm. that was awesome :P .
just ask from u. i got a ticking noice near my ecu. most likely relay ticking noice. from last 2 weeks. do you know any thing abt this...?
im using 10w-60 castrol edge oil for my car. it has done 87000 km on clock. what do u think...any thing better than this...? pls help
HOWTO: RB25DET High Boost mode with standard solenoid
Intended Audience: Stock RB25DET owners
Technical Level: Very Easy
Duration: 5 minutes
Effort: Easy
Result: Fairly Good
!!!Caution/Achtung/Attenzione!!!
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The instructions contained herein are only a guide and should be done with caution, If you doubt see your local mechanic. If you are unsure or are not confident don't do it.
Background:
As you all know the standard R33 RB25DET boost solenoid (value controller) is 5psi until rpm is greater than 4500rpm and then its 7-8psi. Continue reading if you wish to always be in high mode (7-8psi). If you have an aftermarket boost controller then you can stop reading now.
The standard solenoid has two wires running two it, one is constant power which is shared with the AAC value and some other components (see wiring diagram) the other is a ground signal. The ground signal (black wire) is run to the ECU. This wire is grounded when rpm is greater than 4500rpm by the factory ECU. Basically if you give the wire a constant ground instead of the ECU's above 4500rpm ground it will always be open, thus allowing it to be in high mode aka 7-8psi.
The mod:
Cut the black wire and run it to your own ground on the car body somewhere. Find a local bolt/nut or metal chassis component and attach a lead wire to it, then run this lead wire the black wire on the standard solenoid. For testing you could run this to the suspension tower, is has a huge bolt/thread on top of it. The other end of the two wires (black and white) should run to the factory harness plug (black odd looking plug), which can be simply taped up so it goes nowhere.
Be sure not to the modify the white one, as it's power for the solenoid.
See new-wiring.jpg for how it should look
Basically the black wire goes to your new ground, the white wire doesn't change. Make sure you tape up the loose end of the black wire out of the plug and don't leave it dangling around. Now to test
Test:
Start up your car, make sure you don't have any alarms or warning lights etc.. Safety is important!. Instead of your car going into 7-8psi above 4500rpm it will be in this mode all the time, this means when you take off in first youll be limited to 7psi instead of 5 and thus applies for all driving thereafter. Take it for a quick spin and see the difference. You'll notice first is whole different feeling to it and each gear thereafter seems to have more stick about it. Your top end power output will not be changed, ie if you made 140rwkw and you've done this mode it will still be 140rwkw it's just the curve will be sharper as you'll be on more boost quicker
Tips:
If you don't notice any different then you've either done the wrong wire or the ground is strong enough. Be sure to pick a strong ground and make sure its secured properly. You can get gold washer clips which will hold a wire and provide a good ground for use on a nut (see the yellow thing in new-wiring.jpg)
If in doubt you can simply unplug the black factory harness plug and your controller will be in closed mode which is 5psi all the time. With only a power signal the solenoid doesn't function and thus it will always be in "closed" mode which is 5psi
Questions?
How does the solenoid work?
The stock solenoid works like this, with power and ground it will be in "open" mode and let through a maximum of 7-8psi. With only power it will be in "closed" mode and will only allow through about 5psi. The ECU makes it go into "open" mode by giving the black wire ground signal which makes the circuit complete. All you are doing by "adjusting" the black wire is making the circuit complete all the time.
What will happen above 4500rpm now that I've done this mod?
The ECU will still ground the wire above 4500rpm but nothing will happen. As long as the black wire is taped up you will be fine. Of course if you are creative you could run this wire to something else and it will be turned on when rpm is greater than 4500rpm. Crap like turn on the water spray kit for the intercooler, flash a light, do some other crap
I've broken something, can I reverse what I have done?
Should you do some damage or have broken stuff you can get a stock boost solenoid from the for sale section of the forums for like $50 tops, as its fairly useless when you have an aftermarket boost controller. The standard wiring is fairly simple, one is ground one is power. You can't have a circuit without both. See wiring diagram if you are unsure or doubtful.
Have fun and enjoy
** Corrected wire colour mistake **
** Corrected 3 more wire colour mistakes lol Duncan **
  • 5 weeks later...
  • 3 weeks later...
A little confused about this... Been looking thru this thread and cant find my answer. With the earth wire, do you just splice into it? or cut it and earth one end?
Hey guys,
I JUSt did this mod on my R33..
Im getting .3 bar 1st and 2nd gear.. but when im in 3rd it goes to .6 bar around 4000rpm.
I have a highflow turbo, fmic, stock exhaust, stock wastegate actuator, stock ecu.
Does this sound right?
Ive changed two grounding points and it seems to be the same.
Could the lack of boost be because of the lag on my turbo?
Im guessing i did it correctly because it does hit .6 bar (8 psi) before 4500 in 3rd.
I did mine on sunday and all I have to say is... best mod ever! Made the hugest difference in first and second makes the car drive even easier. I tried to resist putting one of these in but the temptation was to great :blink:
I did this mod a few weeks ago and can definately feel a difference, especially in 1st gear and 2nd. Full boost is now at 3000rpm maybe lower
My fuel economy has been horrible though - 16L/100km on this tank as opposed to the steady 10-11L/100km I have been getting for the 6 months before this. I dont drive any differently than I used to either, could this be related to my fuel economy? Instead of cutting the black wire I exposed it and ran a wire from ground to the point where the black wire is exposed. I might reverse the mod to see if it has anything to do with my fuel economy if I dont figure out the problem soon.
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
