My car produces a clicking or clunking noise whenever i change gears or take off from idle, if you take off very slowly you can't hear it but if you take off quicker you can hear it. Its coming from the rear end of the car, and its R33 series 1. Any help or advice appreciated. What could be the problem, has anyone else experienced this? Thanks.
Universal joint - it's a join that will move in "any" direction, and still maintain a solid connection. On a tailshaft, it's the bit that connects the shaft to the diff. As the diff can move (well, in non-IRS cars anyway) and so can the gearbox etc, the join must be flexible.
No doubt someone will have a pic floating around.
guys i had the same problem too.. when to two suspension specialists and still couldnt find anything wrong.. so i did a bit of investigating my self and found it to be my wires in the boot coming out of my subs and knocking against the body of my car.. i also found a pen in there as well as some screws lol... probably isnt the problem but worth having a look..?!?!
I have been to two different places to try and find the source of the clicking noise coming from the right rear of my car. Noone has been able to find it.
To a certain extent the car has always made the noise, and i have had the car for 4 years. Its nto the diff, fluids have been changed many times with no change, its not the uni joint as they have been inspected and found to be in better condition then aother cars in the workshop, and not susp as all my susp has been changed at on etime or another.... so i am at a loss to find the source of the clicking noise....oh and not lieky to be tools etc, as the time when it is easiest to hear is when pulling out of the pits with the concrete wall on the outside and the clicking noise reverberates off the pit wall, plus all the boot trim, spare wheel, jack etc is removed.
It could be anything, including the things i have listed as not being the source of the problem, only i couldnt be bothered throwing money at it when noone knows what it is....if you know the answer you could be the only one in the counthry that has fixed the prob. :(
Its one of those probs that haunts me :(
does it do it everytime you take off? could be just the brake pads moving on the pins, have similar click when i suddenly jump on the breaks... or the handbrake pads moving off...
just a thought
That noise will more than likely be driveline backlash. Not a major problem, just annoying. You can usually avoid making the noise with practice, and by being a bit smoother. And yes, you can do it with a button clutch :D
I suffer "driveline backlash" - when I push the clutch in suddenly - eg i was reversing out of a carpark and someone ran behind me - i get a loud clunking sort of noise. It feels painful for the driveline, what is suffering? Uni joints, diff?
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
