Is it general consensus that if you are putting 350z springs on a V35 sedan, the shocks should be replaced with 350z shocks as well (even if using sports suspension shocks)? I put on the unrevised 350z springs over the weekend and they feel less harsh on the road than the sports suspension. I'm preferring the bumpier feedback the sports suspension provides.
Did anyone get uneven wearing of the tires with 350z suspension? The camber can't be adjusted without a kit and g35driver are differing to whether camber kits are required with a relatively small drop. Had a wheel alignment done which showed the camber is around 1 degree on both sides which way less than the resulting 1.5 degrees they are usually getting the G35.
Regards.
I am running the stock V35 sports shocks without issue. But if you have access to the 350Z shocks and they are in good shape, the certainly fit them. They are probably a bit shorter than the V35 shocks.
But if the 350Z spring rate is the same as the old V35 spring rate, than the V35 shocks should be ok.
I have had my 350Z spring in for a while now and haven't had any tyre wear issues. The rear was able to be dialled into spec without needing a camber kit.
The front is running about 1.3-1.4 deg neg camber which can't be dialled out without replacing the upper control arms with something that is adjustable.
Superpro do make offset upper control arm bushes, but apparently these can only give you +-0.5deg.
Some people said I would go through a set of front tyres in 10,000km without correcting the front camber, others said it will be fine with such a small negative camber.. it seems the latter opinion is correct.
Edited by sonicii
Thanks sonicii, good to know on the camber. Did you find the 350z spring/V35 shocks combo less harsh than the stock sports suspension?
I presume the 350z came out with stiffer shocks as standard and is likely to be the reason in my setup that I'm not getting the rave reviews I was expecting .
I've seen 350z "Track Edition" springs and shocks advertised and the spring markings are the same as standard.
with the revised (stiffer) rear springs, I can feel that it is rougher on uneven roads. Overall the car feels a little better in the corners.
But I certainly wouldn't say it feels 'less harsh' than with the stock V35 springs. - but I also didn't expect it to 'become' a 350Z.
Not sure of the specs of the stock 350Z shocks..
Overall I am happy with the setup now, as I said, it is slightly rougher than the stock springs, but worth the upgrade. I am also surprised that I don't have more issues with scraping on driveways or speed bumps. I do have to watch out for the gutter with angle parking or most car park 'bump stops'
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
