Got a few leftover bits and pieces.
R34 GTT Stock exhaust from the turbo back $50
R34 GTT Stock ECU/ Computer $250
R34 GTT Stock Spring and coils (one of the rears was leaking a little) $50
R34 GTT JDM Flare (Rare) Incl mounting clip $50 (can not be posted)
Pickup from Sydney Northern Beaches or North Ryde area, may post some items at your cost.
https://www.sau.com.au/forums/topic/429201-r34-gt-t-bits-and-pieces/
Price Drops:
R34 GTT Stock exhaust from the turbo back $40
R34 GTT Stock ECU/ Computer $200
R34 GTT Stock Spring and coils (one of the rears was leaking a little) $40
R34 GTT JDM Flare (Rare) Incl mounting clip $40 (can not be posted)
  • 3 weeks later...
ECU Sold.
I still have the following:
R34 GTT Stock Spring and coils (one of the rears was leaking a little) $30
R34 GTT JDM Flare (Rare) Incl mounting clip $40 (can not be posted unless I remove the insides)
R34 GTT Original Amber Indicators $25
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
