Parting out R34 Gt-t street/track car
  • All parts located Ipswich, Qld
  • All parts are from R34 Gt-t unless otherwise stated by Brand or model number
  • All parts as described or money happily refunded
  • All prices are firm or VERY near offer - lowballers can E.A.D
Payment: Cash on pick-up or postal money order. Strictly NO bank transfer or paypal, don't ask.
Post: Will post smaller items at buyers expense - may take a couple of days to organise package and post.
All inquiries via PM or phone 0413 863 207
What is listed is what's for sale, there may be some factory bits still left on the car that may be of use so make an inquiry.
R33 GTR Brembo brakes. Slotted front rotors, EBC pads, plenty of life left in rotors and pads: $1750
R34 A/C compressor: $100
R34 alternators: $75 each
R34 CAS: $150
R34 ABS module: $250
Instrument cluster: $100
Triple centre gauge set: $100
Apexi AVC-R boost controller, blue screen complete with harness & boost solenoid: $250
HDi Boost Controller and gauge, complete with harness and solenoid: $125
AP500 electronic cruise control, complete with steering wheel thumb controls and instructions. If Qld, this setup can be fitted by Chris Rogers. Suit most cars: $250
Power steering pump: $100
GT-R Blow off valve with flange to suit RB25 or RB25 Neo: $75
RB25 Neo fuel rail with Bosch 1000CC injectors & loom: $400
Turbosmart fuel pressure regulator with gauge: $150
Braided brake lines to suit Brembo installation on Gt-t, Gts-t or Silvia. Complete with banjo bolts: $100
Apexi N1 lightweight coilovers to suit R34 Gt-t. These have recently been re-valved by Murray Coot for Australian conditions, in VERY good condition: $1000
Coilpack and loom: $150
Genuine Z32 AFM with plug: $250
Selby heavy duty sway bar, 4 way adjustable. Suit R34 GT-t with or without oversized sump: $150
Front and Rear lower control arms: $100 pair
Rear half shafts: $100 pair
Peterson oil cooler and filter relocater. A rare item that takes the oversized oil filter. Braided lines and fittings: $400
Front adjustable strut brace, unknown brand: $40
Custom big horsepower tail shaft with serviceable universal joints: $300
Stock clutch fan with supertight clutch: $100
Radiator shroud: $100
A/C condenser: $100
Koya drifteks 17x9 +35 offset. One wheel has a crack in the spoke, all wheels are round and true: $300
Pair only, Enkei 17x9 +37 offset. Pearl white paint polished lip, will clean up nice: $100 pair
Nismo style catch can, polished alloy in excellent condition: $75
RB25 Neo gearbox complete with shifter. Suit R33 or R34: $1250
Sparco racesuit - EXCELLENT condition, worn very little. Suit tall, slim driver around 6'1" to 6'2" mark: $300
Power FC with hand controller, suit RB25 Neo GT-t or Stagea: $800
https://www.sau.com.au/forums/topic/429285-r34-gt-t-streettrack-car-part-out/
Hi Noel,
You wouldn't just happen to have the Neo R34 GTT boost sensor?
Looks like this
Located at the back of the block and the tube to it is normally blocked off.
  • post-13786-0-79055200-1375861782_thumb.j
would appreciate it :thumbsup:
  • 1 year later...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
