If its 1pm lunch, we might have to look at booking a number / letting trackside know
Also, going to take at least 1.5 hrs to get to Gosford from lane cove I think, on a Sunday.
If its this is a 100% go ahead I'm going to need numbers so I can ring terry/bec and make sure we have seating.
yep this is it!!! there's enough time for everyone to organise themselves and get their cars ready :)
whats the addy for the meet Craig ?
Let me confirm 100% on Lane cove. I need to alert all the tenants.
I've also contacted terry about the restaurant....got to sort out confirmed numbers.
Watch this space for more info.
https://www.facebook.com/events/214480932044402/ for anyone I don't have on F.B try this link......... here you can get familiar with the cruise route if your not from the area https://maps.google.com.au/maps/ms?authuser=0&vps=7&gl=au&ie=UTF8&hl=en&oe=UTF8&msa=0&msid=213771558366632026141.0004e3e460190cac06899
So the address is 1 chaplin drive Lancove west?
The lane cove meeting point is now approved.
So the start point is 1 Chaplin Drive Lane Cove West.
Please note that any stupid driving will be reported to the police and I will kick you off the property.
I'll start working on the numbers for the booking for lunch now. I was thinking to ensure numbers it would be a good idea to take a small deposit of $10 per person for those that will be having lunch there.....naturally you'll get that deducted from your lunch but it will be non refundable. Others can come and pay on the day but it will be in the lap of the gods as to wether there will be spare seating available.
Thoughts
Edited by Jetwreck
Thoughts
Yep, post up some bank details.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
