I'm about to have the flywheel in the CA machined (mild tune 200rwkw track car).
Can it be safely lightened at all? There seems to be a lot of conjecture about this.
Anything is a gain and it won't cost much more than having it machined. I will ask the place tomorrow, but thought some opinions couldn't hurt.
Clutch is a basic Xtreme HD Organic.
https://www.sau.com.au/forums/topic/429453-lighten-a-factory-flywheel/
Just seeing what the options are. Like any job I do, when it's all apart you're going to have a look around and think how can I improve this or what other things need replacing while I'm in there.
So it was just a case of "if" not "need".
General consensus seems to be it can be done, to a degree, but the risks go up, So I'll just get this one machined and put it back in. I can't justify $300 or so on a new lightened flywheel.
machining the cast iron flywheel is fine to resurface. But to machine till you serious Lighten..... dumb.
The outer skin of cast iron is where it's strength is. removing it seriously reduces the strength.
Bottom line is that there are plenty of true stories about lightened cast iron flywheels letting go. It's when they are put in high load / heat cycles. A clutch and flywheel breaking up a speed is a scary situation. Google this . You should have no trouble seeing the reccomendations against it.
Get a chrome molly one with the new clutch. They are like $400 or less
Nothing wrong with the Heavier style flywheels, go have a look through my build thread and see my custom version... Heavier than stock and awesome!
cast iron flywheel --lightened. Theres a few of these on youtube. You also get this with dodgy clutches too, if they let go.
Heavier flywheels that stock can make the driving /shifting easier. It also depends where the mass of the flywheel is distributed.
Removing rotational mass has significant performance benifits.
The performance benifits of a decreasing the mass are well documented.
Heavier flywheels offer drivabillity . Light weight = performance gains. Is the same for wheel weights.
What performance gains? Can you point me to any info showing this?
Mine has plenty of performance and changing to the new setup changed the car, its so much better to drive now!
Sure. I'll have look for you later. You can google the info pretty easily. Flywheels , like wheel weight are rotational mass. You can find out the physics behind that as well if you would like. It's fairly common knowledge.
The main reason passenger cars have heavier flywheels is to assist in intertia where it helps improve daily driving. Just off idle and cruising smoothness. Probably why the car feels nicer to drive.
The advantage is less mass to accelerate which tends to be more noticeable in lower gears .
IMO the greatest advantage of light flywheels is that the engine revs drop faster on the up changes particularly if you use high revs . Anyone who's drag raced with a manual syncro box knows how important this is .
The downside is such a mod makes it easier to stall when taking off because there is not the initial inertia to send down the driveline . Also especially noticeable in a cammy cranky engine .
A .
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
