When driving, my car will drop a cylinder making it sound like a wrx which I'm sure is to do with my YJ coils I bought a year ago (just changed spark plugs and it's still doing it). The problem is that it only happens randomly as it can happen within 5 minutes of driving or 30 minutes of driving which makes it inconvenient. Is there any way you can tell if the coilpack is faulty by just looking at them? Perhaps driving around at night with the coilpack cover off and seeing if it shows spark? Any ideas?
Edit: If I pull over when it drops and start the car back up, it will return to normal
Edited by Dani Boi
Visual inspection of the coilpack will show up and cracks or carbon tracking across the outside, but given that they're only a year old, they probably haven't suffered the sort of age related failures that you can see.
Best bet is probably just to find a set of known good other coils and either swap them all out and see if the problem goes away, or keep swapping them out one at a time until the problem goes away. Whichever way you go about that you will end up swapping one coil at a time if you're trying to find which one is at fault.
My old RB20 used to drop a cylinder every so often and restarting it did fix it most of the time. And it was caused by a faulty coilpack. Swapped them out with a known good set and it never happened again.
take the cover off coil loom, drive the car until it starts missing, then disconnect each cyl one by one.
one of them you will notice that the engine sound will not change, that is the cyl that you are having issues with. remove the coil pack at a later date and check the loom, also check the injector connector for that cyl too.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
