Sarcasm? haha I don't really have set days that I must work out on.
I usually do every second day then a couple days rest, if I have an extra day rest or miss a workout the next week will fall on a sunday.
Nice work man, keep it up.
EDIT: Realised this sounded contrived, my point being even with discomfort you had a god and got through it for the most part.
Edited by ActionDan
Thanks, what's a rajab? haha I see it everywhere. Swear filter?
It's always an internal battle as to whether I should push through the pain or if I should stop. I'm slightly wiser now so I stop if I have to
Edited by r31slpr
Hip still playing up a bit, hurts in the bent row position, should clear up soon.
Had to walk to the gym today...First world problems haha
20/12/2013
Lunge: 1x8 Bar
3x8 @35
Bench: 1x8 Bar
1x8 @20
3x8 @30
Row: 1x8 @40
3x5 @55 Difficult holding the right position for this.
Pullups: 4 :angry:
Nice deading.
There's a good explanation of Rajab over in the motorsport section.
Essentially it's just an "in" joke from some of the Wastelanders praising Rajab (the engine builder/performance workshop) for anything good that happens any time.
Thanks, it ended up being 4 sets of 2 reps because I did 2 stopped for chalk, did 2 more noticed my leg was bleeding haha tied my towel around it, did 2 more, then decided I may aswell do another couple .
Thanks for the rajab explanation, a lot of stuff makes more sense now haha
Indeed.
25/12/2013
Lunge: 1x8 @20
3X8 @40
Mp: 1x8 @20
4x5 @32.5
1x5 @22.5
Row: 1x8 @50
4x5 @57.5 Will probably stay at this weight for a little while because hip is still hurting in that position.
Pullups: 4,2,2,2
Had a few days off, shoulder is giving me grief again.
Rows went to shit and decided not to do dips.
Will go see the physio as soon as possible.
31/12/2013
Lunge: 1x8 @20
3x8 @40
Dead: 1x5 @90
1x5 @110
2x3 @130
Row: 1x8 @40
1x5 @50
2x5 @40
  • 3 weeks later...
Alrighty couple quick updates.
Haven't seen the physio yet just been working on the shoulder myself.
Got told the other day I'm supposed to include the bar weight in my lifts, so all my previous ones are just the weight that was on the bar not including the bar itself. All future ones will be total, weight + bar.(which I believe is 15-20kgs)
The above doesn't really matter because I've changed to an entirely new program and dropped all my lifts down to about 40kg to start with as its higher volume.
Not sure if I should keep logging progress here or just put it in a spreadsheet.
  • 10 months later...
Long time no update. Still lurking here though
Joined a new gym about 2 weeks ago, did 1rms.
27th Nov: Squat 185, Bench 100, Dead 200
Worked on technique
2nd Dec: Squat 205
3rd Dec: Bench 110
6th Dec: Dead stayed the same, had a shitty day
  • 1 year later...
Been nearly three years since I started this thread. Started out injured, got a fair bit better and stronger for a while. Since then its been all downhill.
Been plagued with injuries for ages, either work related or just because I'm an idiot.
So back to basics.
The ptc beginner program is the only one I've done so far that I consider to have worked well (ie: got stronger & didn't get injured) and that's what I'll be doing again until I stall.
Hopefully it will put me in the right direction.
16/05/2016
Squat 3x10 Bar + Split squats 3x8 Bw (needed to stretch my legs a bit)
Bench 3x8 Bar
Row 3x8 Bar
Ohp 3x8 Bar
Rdl 3x8 Bar
Curls 3x8 Bar
Progression will probably be daily till that slows down, then weekly for as long as possible.
Going to try and update here as I go
  • Like 1
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
