Squat   3x10 85kg
Bench  3x8 72.5kg
Row     3x8 72.5kg
Ohp     8,6,2,8 57.5kg ohp is hard, if I don't make all the reps by the end of the week I'll drop 10% and reset.
Rdl      3x8 85kg
Curls   3x8 20kg? I think. I've switched to oly db's and not sure of the weight, prob about 5kgs
Missed most of last week so no point putting it up
25/07/2016
Squat   3x10 87.5kg
Bench  3x8 75kg
Row     3x8 75kg
Ohp     3x8 50kg dropped around 10% due to stalling
Rdl      3x8 87.5kg
Curls   3x8 20kg db lowering the weight on these too, stop me from cheat repping it
Missed most of last week so I'm just going to write that one off.
This week had to use a commercial gym, pretty much the same as usual. Exception being, having to swap out bb rows for db rows on one day.
01/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Row     3x8 77.5kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
03/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Db Row     3x8 40kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
05/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Row     3x8 77.5kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
