Hi guys,
Just had new wheels on and this happens!
This morning I had to limp home with 2,4 and 6 gears only.
Checked the Cobb which said error code trans PO847.
Disappointed.
Anyone with any experience? Do I need a trans rebuild now?
Thanks.
Hey Max,
I had this code twice, clutch pressure sensor B. located in the clutch mechatronic. It could also be piston seals in the clutch assy. Unfortunately the gearbox would have to come out. I used a second hand sensor first but that did not last long. Now I got the new WillAll sensors and seals that seem to work great. I fitted the sensors myself without a hoist. Not an easy task though.....
Pree
Pree, you got some pics of the replacement process?
Hey Max,
Pree
Simple fix - sensor shit itself, probably, only issue is that tranny needs to be dropped to access it. Hope it get's fixed quickly. Shouldn't cost too much though.
It is only a simple fix if the pressure sensors have been previously remotely mounted....if not then it is transmission out and split it to gain access to the pressure sensors.
Hey Max, it took me one Saturday to jack, remove trans, split the box, install sensors and tsb clips. I waited till Sunday to connect the wiring as I wanted/needed high temperature heat shrink to insulate the wiring. Rejoined box feeding the remote sensors through the little gap. So now all three sensors sit in the pan. Thanks WillAll. Refitted everything by Sunday afternoon. Mind you this was done on jack stands. I needed a transmission jack which I hired. Not long but I enjoyed working on the car. I'm trying to add pictures from my iPhone, don't know how to do it yet. I need more time to investigate.
Cheers...
Edited by pree
Thanks for the write-up Pree. That's bloody awesome - you could do that!
I don't have the hands-on know-how.
I'll be trucking my car to Martin at Willall.
Will let you know how it goes! Might convert to E85 too, while I'm there.
Could be what I had this year a broken seal.
The sensors are on the rear side of this assembly.
URL=http://imageshack.us/photo/my-images/221/sn3p0960a.jpg/]sn3p0960a.jpg[/url]
And another one on the valve body:
See right side
Edited by JDM_R32_R35
Yeah, getting Martin to checkout my tranny and clutch while it's opened up, after replacing the sensors, seals and wear-&-tear parts.
It actually had 2 codes: P0847 and P2715.
Doing injectors and pumps too while my baby is there. Will see what E85 power tastes like!
  • 3 weeks later...
Just got my car back from Martin. He replaced the 3 sensors, gear stops, fasteners and clips. He also had to fabricate a new selector shaft. E85 tune is in (with ID1000 & DW65c) and the car drives like a frikkin beast out of hell!!! Love the meaty midrange pull - so smooth and aggressive. Haven't really had a chance to go WOT to the redline yet on normal roads. Need a strip or the track. Gear changes are now very responsive and smoother change. Martin also had to swap my 3rd gear synchro with the Reverse gear one, as the 3rd synchro was quite worn. Will post more on E85 power when I get more seat time. Dyno showed a massive gain on my previous 98ron renew tune. Plus an amazing 1072Nm of torque at 4650rpm! Overall - very worthwhile mod. Now I gotta re-calibrate my senses to all that power.
Torque figures gets skewed due to the gearing (diff, trans, etc). That's why auto cars that are roller/chassis dyno'ed have high torque figures. The most accurate way to measure the torque is the stick the engine on an engine dyno ;).
Power figure is fine. But I like to worry about the area under the curve than the peak value. Like you said, the way it drives is the most important factor in any mod (unless you're going for dyno numbers only). You can see that jump around 80 km/h mark = good good :D.
But it's pretty cool to say that you car puts down over a thousand Netwon meters of torque hahahahaha.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
