Pretty keen for this - does anyone know an average price for a wakie day?
My last pay day is next fortnight - need to see if it's in budget.
$150 for day
$50 for liecense
$80 fuel to get there
$40 top up
$80? for a tank at lunch?
$40 top up for ride home
$10-20lunch
$40 oils
Total: $490 - sounds about right?
Edited by RosieR34
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
i used about 80litres total for the day you use a half tank getting to goulborn and back so petrol cost is about $130
buy a 1L bottle of oil $15
so about $410.
  • Like 1
It is not totally unlikely that your car will break, I had mine trailered back once, at a 350$ cost. Due to a bad driveline noise. (turned out to be a loose pully.) But it's not totally impossible, you are stressing the car and pushing it, so it's not impossible that a turbo could blow, or you have some kind of failure.
My advice apart from what everyone else said, is do some slow cooldown laps as well, dont flog the car the entire session. I was doing a fair few hot laps and would then do a slower lap to give the car a break.
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
Also budget for a potential set of new tires, unless you have slicks or semi slicks, you will put a bit of wear on your tires.
you determine how hard you push your car. you dont need to go all out and non stop.
if your car is on its last legs for tyres or brakes etc or already has issues on a daily driver level, then sure best to give it a miss.
same deal if your pushing it financially but otherwise lets not get too pedantic.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
