Hey up forsale is my very well looked after red pearl metallic r32 gtr
Has had a rebuild 4000ks ago,
Parts involved in rebuild are:
New AVL race bearings
New genuine nissan rods
New genuine nissan timing belt and both bearings
New gaskets including head gasket
New N1 oil pump
Crankshaft machined and straightened
New crank seal and rear main seal
Also other types of gaskets, seals and hoses done
Over $5000 in receipts
General mods and accessories:
New heavy duty clutch
Hks dump pipes
Full 3.5inch hks super dragger exhaust from dumps
Power fc ecu with hand controller
After market radiator
New hks oil filer
Hks cams 272 9.7 lift
Hks valve springs kit
Hks camgears
Short shifter
Bee r rev limiter
TCS 4wheel to 2 wheel controller (not fitted)
TCS also has front wheel torque control
Bilstein suspention on legal low
Gktech hicas lock bar (not fitted)
Has alpine head unit and speakers
Brand new full set GTR floor mats 2 piece front
3 piece rear with GTR logo
N1 rear boot lip
N1 front bar vents
Apexi blow vales
Wheels are brand new ENKEI's RPF1's 17 by 9.5 +18 all round with brand new federals 596 tyres
245/45/17 all round
Wheels and tyres have yet to see more than 5ks
Currently tuned at 246.6kw
Safe tune have dyno sheet
And still has 6 months rego
Only problem with the GTR is one airflow meter is faulty causes the car to shut down every know and then but I have brand new genuine Bosch z32's afm to go with sale ( not fitted)
Besides that its a very clean car inside and out.
Looking for $18000 negotiable but please view it before you throw me a price, also will take around $1000 off if you want it without wheels and bring your own
For more information or photos please feel free to contact me raz on 0433154816
No swaps
https://www.sau.com.au/forums/topic/429961-nissan-skyline-r32-gtr/
Who did the rebuild? That's a pretty good price.
It Was done by sinergy motorsports a very respected workshop in Adelaide S.A
I brought it from a guy from there because that was the only colour I wanted in the gtr range
And it was the cleanest one I found.
I had big plans for this car but unfortunately I didn't get a chance.
Iv owned it for about 6 months and only drove it a few times, since I work in interstate transport
Thanks
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
