Hi guys.
I'm doing the headgasket on the Stagea atm. I've got as far as getting the headbolts out but I can't seem to budge the head. Does it require a bit of force to separate it from the block or are there a few hidden bolts?
rb25det neo btw.
Cheers,
- Lance
https://www.sau.com.au/forums/topic/430028-rb25det-head-removal/
maybe this - Theres a ten mm bolt(I think ten mm) at the front left side of the head behind the inlet manifold. Is a real bitch to get out with manifold on, I replaced mine with an allens key head one after doing head gasket to make easier in future.
I guess that answers the question about the locking up engine? :/
Kind of. Injector 4 stuck open and it hydro'd itself when I was checking other stuff. I had the injectors cleaned but when I did a compression test cyl 4 and 5 came up low so I was thinking it was a break in the head gasket between the cylinders. Turns out it was so it's off with the head and new gasket time.
I'm unsure if it was related to the stuck injector but it's all being fixed now.
Cheer man, I figured it out soon after I posted this asking and scratching my head a bit. The one up the front is a real bastard but it's all off now. Cheers for the help.
- Lance
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
