At what point do I need a management/ a tuner / tune.
I have a Rb25det with a gearbox. I was thinking about replacing the turbo with something a bit bigger. Complete with a external wastegate setup. Injectors and maybe a 300zx maf.
I saw some aftermarket brains selling that have a tune with bigger injectors and the maf. Makes sense?
Would I need a management and a tune for those mods?
https://www.sau.com.au/forums/topic/430205-management/
Remember to try and install all mods together and only get 1 tune.
No point getting a tune after injectors. Then another tune after going big turbo etc.
You will definitely need to change ECU's / management. Cheapest would be Nistune, and other and more expensive options would be haltech, blackbox, Link G4 etc.
https://www.sau.com.au/forums/topic/430205-management/#findComment-6968835
You need an ecu (management) for the mods you describe.
Do a few weeks reading on the forum and you will form a better understanding on the topic. Don't rush into anything just yet, there is a lot to know before you can commit to something like that.. More than you can learn by asking questions in one thread, you will need to do lots of reading.
Feel free to PM if you feel really lost. Good luck.
https://www.sau.com.au/forums/topic/430205-management/#findComment-6968858
+1 this man he knows
  • Like 1
https://www.sau.com.au/forums/topic/430205-management/#findComment-6969226
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
