Can someone get me from my place for the Casula meetup and then a trip down and back? Currently can't drive, and all that. Keen to come. (will need room in the back seat for my crutches though)
(also wanna be inside at foods if possible)
I no have skyline but you're welcome to come with me.
Must like singing to Johnny cash songs
All good :) thanks! So yeah I'll need picking up in Liverpool. I'll pm you my number so you can let me know when to haul my ass downstairs.
If you want to do musical cars and jump in mine on the way up the pass after the meet point more then welcome to
ok, about to book table.
these are the people I have;
levinboy +1
nytsky
crashdown
sinno
ianjb
moelders
liz
mick_o
deka
fez25 +1
r32gojira +1
manuel kasko
cpd
humbla
if ive missed you, or you have just seen this, let me know asap.
calling to book at noon.
looking to be a good turn out.
see you all then.
ok, just booked a table.
Unfortunately, could only book for 10.
the restaurant isnt big enough to cater for the amount of people coming.
so, for those wanting pizza, they do take away and can be eaten outside.
those wanting the full menu, will require a place at the table.
Hopefully we can sort this out between ourselves, or I will have to end up selecting.
sorry for the bad news.
Thanks for bearing with me.
cheers, luke.
cheers, luke.
happy to eat outside on the condition there is no rain.. If there is rain i will reclaim my table seat ;)
im really hoping its weather like today.
so nice out in the sun.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
