Can someone get me from my place for the Casula meetup and then a trip down and back? Currently can't drive, and all that. Keen to come. (will need room in the back seat for my crutches though)
(also wanna be inside at foods if possible)
I no have skyline but you're welcome to come with me.
Must like singing to Johnny cash songs
All good :) thanks! So yeah I'll need picking up in Liverpool. I'll pm you my number so you can let me know when to haul my ass downstairs.
If you want to do musical cars and jump in mine on the way up the pass after the meet point more then welcome to
ok, about to book table.
these are the people I have;
levinboy +1
nytsky
crashdown
sinno
ianjb
moelders
liz
mick_o
deka
fez25 +1
r32gojira +1
manuel kasko
cpd
humbla
if ive missed you, or you have just seen this, let me know asap.
calling to book at noon.
looking to be a good turn out.
see you all then.
ok, just booked a table.
Unfortunately, could only book for 10.
the restaurant isnt big enough to cater for the amount of people coming.
so, for those wanting pizza, they do take away and can be eaten outside.
those wanting the full menu, will require a place at the table.
Hopefully we can sort this out between ourselves, or I will have to end up selecting.
sorry for the bad news.
Thanks for bearing with me.
cheers, luke.
cheers, luke.
happy to eat outside on the condition there is no rain.. If there is rain i will reclaim my table seat ;)
im really hoping its weather like today.
so nice out in the sun.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
