Think carefully about why you want to change to a FFP before you do. I can tell you now, they don't make working on the car easier. They make it a hell of a lot harder. Spark plugs are one thing, getting in and around the engine bay is another, and oil filter changes are a right pain in the ass.
That said, I love my Plazmaman. Just recommend thinking about it, if you're doing it to make life easier then I don't recommend it.
Yeah what Hanald said...i almost put me on my car till I realized how shitty it was going to make working under it...theres a starter motor oil filter and a lot of pipes under there and luckily none of them usually go wrong ...but if they do you are in for a world of hurt
Main thing that sparked the idea was the damage to my current one. If I replace with another second hand one of the same age its only a matter of time before something similar happens so thought I might as well replace with something brand new and neat looking. The only work I really do on the car engine wise is the service.
what is the damage?
The top rad hose connection has rusted away and isnt clamping properly. I have also searched a simple fix for this problem, asked questions in similar topic threads and come up with nothing.
Even if it has to come off for repair, may aswell replace with something completely new.
Edited by FordyR31
this for sure, underneath is a nightmare
If you want to use a front facing plenum but are worried about oil filter changes being difficult maybe think about using a relocation kit for the oil filter? I didn't find changing the oil filter hard at all with my Greddy plenum. Aswell as installing my oil cooler n relo kit on the ground.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
