All parts from a 1994 Series 1 R33 gtst 4 door I wrecked, cheap cheap!!
Many parts are pick up only unless stated otherwise so read the description carefully.
Sedan boot lid $20. Pick up only.
Rear hubs $20 each (includes uprights). Pick up only.
Front and rear sway bars $20 each. Pick up only.
Rear cradle (bare cradle) $20 each Pick up only.
Non abs brake master and booster $20 each. Can post.
Door cards- no switches included $20 each. Pick up only
Very good condition except one small blemish as shown in photo.
Rear 4 door window switches $20 each (or $40 for all three, driver's switch sold). Can post.
A pillar trims $20 pair. Pick up only.
Doors $20 each. Pick up only.
Rear bar, suit respray $20. Pick up only.
Door lock kit - doors, ignition, boot with key $50. Can post.
Steering rack $20. Pick up only.
Indicator and wiper stalks $10 each. Can post.
Steering column $20. Pick up only.
Kick panels $10 each. Can post.
Dash plastic surround (pick up only) $20
Dash pad $20 pick up only
Sun visors $10 each. Can post.
Front guard mudflaps $10 pair. Can post.
Sold/unavailable:
Motor and gearbox, headlights, airbox, clutch master, bonnet, passenger guard, under stereo pocket, engine fan, speedo cluster, lower control arms, factory stereo, centre console, stock suspension, castor rods, cat temp sensor, inner guard liners, fog lights, climate control, shifter surround, front bar and grille, AFM, ECU, drivers window switch, side mirrors, stock rims, diff, rear brakes, radiator, interior wiring loom, steering column plastics, handbrake, stock intercooler and piping, rear vision mirror, interior lights, front hubs.
How much for the plastic steering column surround thingy, pending it has no holes or blemishes? Posted to 2444 Port Macquarie?
Let me know :)
pm sent :)
is the front fender the same as for a coupe or are they different? sorry if noob question.
pretty sure they are the same
much chance you'd have a stock or a not too loud exhaust catback for a r33 sedan? also if anyone knows if the front end (guards, front bar, bonnet headlights) are the same between sedan and coupe??
nah exhaust sold already, not 100% sure on the front end parts but I only have the driver's guard anyway.
Wouldn't happen to have a speedo drive for RB25 gearbox mate?
i may have one on a stag front cut i have, need to check for ya to make sure it's in good nick
pm me if you want it and i'll check it out
  • Like 1
Hey Mate you dont have the space saver spare wheel by any chance?
Also interested in the radiator support/ boot latch with the horns attached
nah no spacesaver, bonnet latch/rad support is still available
pm me for bank details
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
