So you're going to take your car back to the same dodgy mechanic?
i've already paid for the turbo what else can i do? he has to put it in and retune it for free if he's ripped me off yeh? i might as well get it done there then get it looked over with another mechanic unless there's another way i can do this :S
Yeah you got shafted alright. Best bed is to build a case up against him (receipts vs what he's actually done, which means getting another professional to look at your). It's going to get pretty tough for you now man. Hopefully he's less of a dick to you the second time round and actually fixes the issues. But that won't happen, because if he was like that, you wouldn't have issues in the first place!
Perhaps look into Fair Trading, maybe ask someone in your state if they know someone who can give you advice on this matter.
surprisingly he was really nice about all this and offered to fix it, guess my anxiety got me stressed for nothing, thanks for all the advice but guys!!
edit: he played around with power fc and fixed the knocking and the high idle, but he reckons a gasket could be leaking now so he's gonna check that out
Edited by fozzysrb25
just because a part may have NISSAN cast or stamped into it doesnt mean that its made by NISSAN
*sigh* thanks Captain obvious ;) think you're missing the point. An AFTERMARKET Garrett turbo I.e a Garrett GTX3071R wont have a nissan housing like the O.P claims he paid for!
    • It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.  Hardest part was finding someone willing to customize and fit it up with trial and error basically. Whereabouts are you located? - I had my work done locally in Wangara.
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
