Im looking at getting some swaybars for the 32gtst. it is becoming a track car, not a drifter, so i want to buy the right ones.
Selby looks good as i can order what i want.
However i dont know what to order.
Obviously blade adjustable, but what sizes front and rear for a good balance?
I know this subject has been covered (yes i searched a lot), but its basic info, for street use, and whiteline are different to selby.
I dont know if theres anything else relevant. Silvers neomax suspension, solid cradle bushes(thats another question, change? what to?), hicas gone, adjustable this and that.
Thanks.
https://www.sau.com.au/forums/topic/430436-r32-gtst-swaybars/
It's not hard. For really stiff result, put 27 adjustable on the front, 24 adjustable on the rear. You'll probably end up with the front one adjusted away from full stiff and the rear one at max stiffness. For less of a max stifness effort, 24 adjustable front and rear, with the rear probably set to the softer end and the front at the stiffer end. Although those recommendations will really be affected by the relative spring rates.
Realistically, unless you are a race team with budget, you cannot make this "correct" with just one setup anyway. Some will argue that the right way to set up suspension for the circuit is to use the lightest bars you can. The bars are just used for tuning the handling balance. The overall roll resistance is obtained by selecting stiff arse springs. But even then that's a hassle, because bumpy tracks and smooth tracks require different compromises between spring and ani-roll bars (note there's no such thing as a swaybar on a car that's not towing a trailer). And driver preference has a lot to do with it too. You may have two cars in the same team (so the same technical backup on both, with the same engineer) and the two drivers might end up with opposite spring/bar setups and still set similar times. Make them swap cars and they will both go slower.
Yes ill always be a noob racer, but im getting enjoyment from messing with my car. you know what i mean. ;)
So 27 f 24 r is a good all round starting point
Ok, basically in general front stiffer than rear
Right?
haha good point....the quality has never quite been the same since they started manufacturing offshore :(
from memory Roy had some trouble with whiteline bars on this 32
correct, he went to Cuscos.
Nope, and sometimes onshore they would measure from the wrong side of the bar bwahahaha
Yuh, my experience mirrors the above. Front and rear 24mm bars just fell onto my R32. Only hassle with the rear one was it would have helped me to get the car further off the ground before starting work! Granted, I had to put the chassis mount bushes for the front bar onto the wire wheel to remove enough material to make them fit into the D brackets, but I don't take that sort of obstacle seriously.
Sorry to hijack thread but also interested in getting some sway bars down the track..
No drifting.. :)
Question is, how can I identify what sway bars are already ON the car? They look stock to me and can't find any markings.
Edit: Maybe get some vernier calliper's and measure how thick they are?
Edited by Zrobe
You can just measure the thickness, but that might not tell the whole story. The stock front bars on R32s are hollow, hence they are much lighter than a similar sized solid and also somewhat less stiff than a similar sized solid. It is not possible to know exactly how thick the walls are on these hollow bars though, so it's not possible to calculate hoe stiff they are relative to a different sized aftermarket bar. If you have or can make a rig to test how stiff they are then you can compare them. Making such a rig is not super difficult, it's just a lot more work than most people are willing to put into it.
FWIW, my (originally) auto R32 (also a 1993) had a 16mm solid rear and a 22mm hollow front.
Okay, no worries thanks heaps.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
