Hi all
Im upgrading my front and rear diffs with Nismo gt Lsd pros on r33 gtr v spec.
Now the front is straight forward with 1.5 way .
The rear im getting a non v spec housing and drive shafts and bearings......
My question is for mostley street driven car with a few dargs a year and maybe 1 or 2 track days a year would I go 2 way or 1.5 way?
Thanks in advance
https://www.sau.com.au/forums/topic/430508-2-way-or-15-way-nismo-gt-lsd-pro/
If it was me
Front = Quaiffe Helical LSD.
Rear = Nismo GT Pro 1.5 way... new carbon model if the budget stretches that far.
Personally I think the 2 way is too aggressive for anything on the street, and I'm currently breaking in a nismo gt pro 1.5way which drives really nicely :)
thanks for that Infamous I thought about Quaife I heard good thing about nismo + diff shop recommend nismo(can be repaired easily if it needs to be) and wanted to stick to one brand I could not find a rear Quaife one for a good price ($1700 just jap).
so 1.5 way is the way to go thanks mate
If it was me
I also have the same setup. The GT PRO is currently set to medium. I think it's a little too aggressive atm. I'll prob back it off soon enough. Where is your's set to?
The rear definately changes how the car turn's and powers out of corners... In a good way ;)
Piggaz, running the lowest setting for now... good so far!
A couple of clunks when it was cold, but once warm all good, just have to get used to it 'skipping' haha
I had a few other things done in the rear of the car to tighten it all up (bushes, new tailshaft etc), but it's definitely night & day how it comes out of corners now massive improvement for something I never considered as being 'bad'.
Did you do the diff bushes also? I chucked a set of alloy ones in there. Transmits a bit of noise through the cabin, but nothing really to whinge about. Definately improved the shift feel also!
OP. I would think a 2 way might be a bit TOO much.
Nismo diff bushes (reinforced rubber), redid the subframe with whiteline bushes also and the CF one-piece tailshaft.
Removed every bit of slop & random bang/clangs that the rear end had.
I get some noise coming into the cabin, but it's not bad... I kinda like it, like engine surround sound :D
+1 on shifts feeling better
1.5 way here as well. Mine was on the softest setting.
it was tight to start but after 1,200kms of driving and giving it a solid flogging it settled down (front settled much faster, around 400kms) and would only skip on mid level turns on concrete and in tight carpark turns. If you don't want any at all just add Penrite Friction modifier, that'll stop any chatter totally.
With a Nismo front/rear - get ready for some 4WD powersliding, just have to bet into a corner & tap brakes/lift off the throttle and turn, let it glide and then stomp the pedal to the floor and have some fun :thumbsup:
f you've modified the transfer case you'll pull even harder out of the corners again.
IMO after having done Transfer case then Front then Rear diffs... I'd do that again before chasing power in a GT-R, certainly made the car so much more enjoyable to take on hill runs
Only problem with doing all of that is not matter how i threw the car around I could no longer get the car to do 4WD helli's like it would with stock diffs front/rear. Just something odd i noticed.
What mods did you do to the transfer case?
More plates. Allows more front drive.
This. Although I believe maybe pressure as well?
More lockup, sends power forward better... Drive one with the mod and one without and you really notice a difference in minutes it's that obvious
Also they are on average 15years old and often overlooked in terms of servicing/replacing etc
May I ask you how you got it serviced ? I only know one kit to date and its on gtr.co,uk selling for about 1000$..
Also, part my english ( second language), what do you mean by 4wd helli's ?? previous post. With all the mods done on a proper -5's setup with Star spec Z2 tires, I still seems to spin a bit in acceleration so I'm interesting in doing the rear diff and maybe transfer case in order to gain more traction.
Oh and , Nismo seems to be making the best diff isnt it ? I was thinking about the GT as well. vs. the cusco
Edited by cobrAA
I'm also upgrading the front diff to a nismo 1.5 after getting the sump modified. Is it also necessary to upgrade the rear diff also? Ill only be wanting to make 350aw/kw. And if so should I get nismo for the rear or another brand?
Depends. Put the front in and see how it goes.
When I put my front in, my rear started single pegging. However, my car is a vspec, so maybe the attesa computers had a hissy fit.
^ kinda like that, but with stock diffs i could get it going around and around as if i was on a 50c coin. Post diffs, it would only get to about 3/4 around and stop... Was kinda gay in that respect.
Put it this way - I could launch @ 8200rpm with 350rwkw or whatever and there would be minimal wheelspin with 285/18 AD08s, it would just grip and fly outta the hole.
There was no wheelspin 2nd/3rd at all.
  • Like 1
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
