I am parting out a r32 gtst the car is NOT complied so cant be registered so I am parting it out... engine has low comp in no.1 and blows lots of smoke... car is silver and I am not selling it complete unless you want to pay $5000
bonnet - $150
type m front bar - $170
type m sideskirts - $170
rear pods - $100
seats - $150
cluster (65,000kms) - $80
speedo cable - $80
cusco strut brace - $100
front coilovers (I think hsd) - $350
rear coilovers (yet to check brand but dont match the fronts) - tbc
non abs bmc - $80
centre console with mint lid - $50
radiator - $100
fmic with alloy piping (near new) - $200
3'' catback exhaust - $200
5 bolt lsd - $150
drive shafts - $150
door cards - $80 for pair
engine crossmember - $120
steering rack - $80
gearbox - $450
bare engine with low comp in no. 1 - $150
front reo bar - $150
mint dash with vents - $250
projector headlights - $200
full manual conversion - $900
5 stud conversion - $450
front guards - $80 each
tail lights - $100
rear reo bar - $50
mirrors - $30 each
everything is for sale besides the seatbelts pm or 0420 767 957 for pics or more info
located springwood 4127
https://www.sau.com.au/forums/topic/430563-wrecking-1992-r32-gtst-complete-car/
Cheers Corin, it was the coil packs that were playing up, though I'm still interested in the afm for one of the other 32's. I've got rego and insurance next week, but if you still have it in a fortnight I'll more than likely grab it off you, but if someone else wants it, by all means sell it to them.
By the way, that exhaust I picked up from you was much less noisy than I expected, which is good :) exactly what I wanted, no drone either.
Mike.
No worries Mike I will still have an afm... good to hear that your happy with the exhaust :)
Mayby4 the front bar is sold, I still have the rest...
Edited by SIFTY32
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
