Hey all,
Just bought a v35 350gt 03 model, picked it up fairly cheap and keen to make a profit on it. But in the mean time this VDC system really shits me, even when VDC is 'off' it only changes the parameters of the VDC algorithm which just delays the time in which it takes to interfere.
Anyway after trawling the net i found how to disable it correctly while still keeping ABS active (pulling the vdc fuse disables ABS also), many of you may already know how to do this.
Just interested to see if it's worth me making a 'How to' thread for everyone else that's frustrated by this safety feature.
On mine holding the VDC button in for around 10 seconds disables the VDC system to allow me to do standstill burnouts and drive on the track significantly more aggressively. It would seem the Yanks G35 do not have this feature, so they have created a hard-wired unit that does it with a switch.
I've tried this on mine, and it still flashes 'slip' on the dash whilst drifting and brings my drift to a halt. (can do stand stills in this mode though). What year model do you have?
EDIT:
Just noticed you have an 03 model also.
Edited by FredFrothen
Yeah 03. I haven't tried drifting, but I can do a very mean standstill and figure 8 burnout with no disruption by the VDC system. Maybe when you drift you activate the anti-yaw system, which I believe can't be fully turned off?
  • Like 1
Yer that's what this mod messes with, the 'g sensor/yaw sensor'.
when I did a skidpan in mine the slip light seemed to only come on when I used the brakes to help swing the back around
Was a lot mor obvious in the afternnon when it rained and whenever you used the brakes it would thing you are locking up so the ABS/anti slip chucked a spaz... gave up after that
When you hold it for 10 seconds - is there any indication that it's different from just turning it off? Can you actually feel the car behaving differently?
Reason I ask is I've tried both at hillclimbs & gymkhanas, and I can't feel anything different. I'm not convinced that there is a difference. I can tell you that Collingrove with VDC on is not much fun - first sign of slip & it basically cut power. Was the first run on a cold wet morning & thought I'd play safe - duh.
Under the centre console there is a bosch sensor;
add a switch into the orange wire
be warned; you can't reactivate traction control unless you clear the code in Cipher, or restart the engine.
No there is no indication. But I know it has turned off when I can rip a standstill skid or do figure-8 burnouts
^ 10 points, this was the write up i was going to do.
Probably still will for future reference, plan on doing it friday arvo or saturday. Will include pictures and dis-assembly pics from the workshop manual.
As for holding the VDC button down for 10 secs, when i do this the 'VDC OFF' light goes out.
  • Like 1
Joys of base model sedan. No VDC, No traction control.....Nothing. Dont have to worry about this crap. Wish you guys all the best
They all have traction control and ABS. but VDC was an option on the 250GT and 300GT.
    • Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
    • I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
