  • Replies 275
  • 3 weeks later...
So Fez and I have booked accommodation at the Mawson Lakes for Nats and are now looking at overnight stays for the trip there and back.
The plan at the moment is:
* 20th Sydney -> Mildura (10 hours)
* 21st Mildura -> Adelaide (4.5 hours)
* 25th Adelaide -> Wagga Wagga (9.5 hours)
* 26th Wagga Wagga -> Sydney (4.5 hours)
Who else is road tripping to Nats? Open to suggestions on route changes and accommodation.
Yep im road trippin from gosford, that plan sounds ok to me...
Would be nice to drive along with some others whilst im trailering my 33...
Im looking foraccommodation to share if anyone is interested both in sa and along the way
Great. At the moment I've book a 2 room apartment at Mawson Lakes for myself, Fez and Fez's GF but I can look at changing that to a 3 bedroom but we should have a couple of others coming down too who might want to share (hoping to catch up with Luke at the Texi on Monday to discuss). Once we have numbers and decide where to stay in Mildura and Wagga Wagga we can figure out the sharing arrangements for those stops (open to suggestions).
I think the 7-11 on the hume hwy after picton would be a good spot to head off from so that people can get through Sydney how they like. Suggested route for the first day:
https://maps.google.com.au/maps?saddr=Unknown+road&daddr=Wagga+Wagga+NSW+to:Hay,+NSW+to:Mildura+VIC&hl=en&ll=-34.292537,150.620327&spn=0.114167,0.161705&sll=-34.318062,150.524883&sspn=0.114132,0.161705&geocode=FSTh9P0dbJT6CA%3BFZkI6P0dkWDICClvn-CIR5kYazFQ70OQtAkGBA%3BFf9t8f0dLiOiCCkR7xklyX7gajHgJESQtAkGBQ%3BFaMN9v0dGNJ4CCnDmffsaQTDajHw1KAwpHkFBQ&t=h&mra=mru&z=13
Obviously you guys know i am out for this.... Its a shame as i was really looking forward too it but in this case something better came up ;)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
