This is such a milestone !
1,000 posts milestone !
Shoutouts !
Master Mechanic Rob - Always sucha m8 to help out. Probably has a closer relationship with Rosie than I :(
Richard- Such a troll ! or 'Master Punster'. Found Rosie for me :P
Chris (dontyellplox) - Cruise buddy. Always keen to show up even if only one other person is attending.
Princess - Always gives good advice with carz and I always know where you're coming from Troy, even if no one else does :P
Anthony - Always have a good chat with this fella - I also tell your story about your R32 and engine blowing within 2weeks. Sucks :(
Mik - Always seems to bring up the morale even on the worst of days, always keen to come to cruises.
annnnd anyone else I forgot :P
  • Like 1
https://www.sau.com.au/forums/topic/431008-1k-fred/
I do.
Shoutouts !
Just noticed I got a shout out. YEAH BOY! <3
I'll be sure to drop yo name at least 10 times in my 10,000th post :) hahaha
https://www.sau.com.au/forums/topic/431008-1k-fred/#findComment-6993294
Haha! Congrats post whore =P
Haha, I'll be overtaking you soon !
I tried to find my post average on my profile, couldn't find it. But it would be close to 10 posts a day I reckon :P
@Princess - 10k is a HUGE amount of posts lol At your reply rate in this thread, It wouldn't suprise me if you reach 10k in 2 days :P
Edited by RosieR34
https://www.sau.com.au/forums/topic/431008-1k-fred/#findComment-6993296
Yeah it's a shame that feature is gone :( I was at like 15+ for a while in '11 haha
  • Like 1
https://www.sau.com.au/forums/topic/431008-1k-fred/#findComment-6993312
And i thought i used the computer too much! :laugh:
Less time on the net = more time in the shed.
Time to get some tools guys, and spend more time with her, love is a two way street man. :wub:
The other one says if she had wheels and a motor id pay more attention to her! :w00t:
https://www.sau.com.au/forums/topic/431008-1k-fred/#findComment-6993486
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
