On the air intake on my R34 Neo there is a large plastic box attached to the throttle body and then to the filter housing outlet pipe.
Am presuming its an air baffle or dampener of some kind. What are the consequences of its removal? Just wanted to tidy up that area cause it looks cluttered and poxy. There is also a small one hanging below the pipe from the air box too. Thought or suggestions please?
Neil
https://www.sau.com.au/forums/topic/431021-air-intake/
Interesting. Haven't seen that before. Possibly a dampener as you said, most likely for noise reduction.
In any case, when my car was NA it didn't have that. So I'd say no consequences in terms of how the car runs.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6994313
Thanks fellas. Was thinking same. @ Martin yours could have already been removed before you got the car possibly. @ Andrew yep can see the honeycomb moulding on the outside of the box. Have some assorted silicone bends laying around the shed so will remove and see what happens.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6995147
Yes, no doubt. So I'd say you will be fine removing it :thumbsup:
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6996345
the smaller box, hanging lower towards the airbox is a Helmholtz resonator, leave that on otherwise the intake is going to hum a very annoying note, it sounds shit without it.
you can remove the larger box, replace with a 3 inch 90 degree silicon joiner.
you'll need a bit of 3inch tube to sit inside the remaining plastic intake as a solid base to clamp onto (like a solid joiner between the silicon 90degree and the plastic intake)
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7006960
http://www.brighthubengineering.com/machine-design/84316-how-intake-resonators-improve-volumetric-efficiency/
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7007571
#@iseekool
thanks - the link is a good read, i'll be reinstalling the larger box tomorrow to see if it does increase the torque slightly (or my help with fuel economy, which is fkucing shirthouse for an NA) as i too ripped that large box out to clean up the engine bay.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7008249
  • 2 months later...
when i got my r34 I replaced my big box with a 90 degree pipe as it has a crack in it and was leaking, the smaller box had a crack in it aswell so I closed that off. Although my car got slightly more responsive and slightly better on fuel. I also had to replace the radiator and couldnt fit the 'cold air snorkel' as it didnt fit in between the radiator and the bonnet. So with all of that combined it sounds like a vaccum cleaner at idle and sounds like ITB's at 4-5krpm WOT.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7118353
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
