Mugabetown - Whoretownin' At It's Worst.
Any indication of when? What did he say about the FPR pressure?
Indication early next week
They pulled the fuel pump out and identified a small kink in the line
I told them about the FPR and Ben (I think I was speaking with a Ben :dry: def not Sean as he was on the Dyno) put a fuel gauge on the car and he said its reading 300kpa so thats a good sign (approx 43psi)
Still need to do a few more poawa runs and hopefully its done.
Awww thats kinda sucks
Never had such a hard time b4 with mechs and tuners - everything appears to be lob sided theses days :/
well thats good.
The EFI thing is unfortunate, he would have had a tight schedule leading up to powercruise then when yours required extra work there just would not have been time to do so with out fecking everyone elses schedules to hell.
I actually feel kinda bad about recommending you go there now, but I still maintain the tuning work will be worth the wait! Sorry! :(
Not your fault mate.
I am sure Sean does good things. Which is why he is so busy too.
Bad timing appears to be my detriment.
Nothing I can do there but try to play my cards right.
A smart man told me once 'that good things take time' he knows who he is :turned:
Hopefully x all fingers and everything else the Ant-eater will be done and I will be driving it :worship:
I remember going to EFI/ERD last year just before powercruise. Let's just say insanity was an understatement. They were BURIED under work.
yep its really full on, same thing before Jambo
I've been forever pondering lately what gets prioritised through workshops / tuners
seems like FIFO is not something you can rely on as turnaround indicator
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
