Mugabetown - Whoretownin' At It's Worst.
Awesome exec meeting was awesome! :)
We've just planned out 2014 and the end of 2013 and have something every month! It's awesome sauce!!!!! :)
That's something a month to do with driving. This doesn't include dinners and monthly meets.
you qld folks are very active.
Yeah. We're trying to grow the member base and are trying to get a lot happening.
We have an awesome exec team who are working really hard to make this vision a reality.
Worth it though nick... seen the abomination in the car park up at powercruise... good arvo up there.... thinking about going back tonight myself
Hahaha how did u find it it was hidden in the car park lol
Was walking thru ans walked right by it tried to shoot you a msg on here to come and say gday. But I couldnt get signal.... o that note there were some nicer cars in the car park than were on display at some points
Haha yer I couldn't get signal either, actually had a guy yell out to me on the way out and ask if it was a gen 3 lol
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
