Mugabetown - Whoretownin' At It's Worst.
Eating at your desk is bad for your health, your moral and your productivity. Just sayin'
Also, a call for help to all my fellow whores! http://www.skylinesaustralia.com/forums/topic/431683-request-for-photos-and-video-from-ths-year/
Why?
Long story short not having a proper period of downtime at lunch increases stress significantly and doesn't give you a chance to recharge. As a result you are less likely to be as creative, as productive, as happy or as healthy in the long run and your work output and quality declines both in the short and long run.
There is a decent amount of scientific research in the area, I can dig some up for you when I'm not so swamped with other research assignments if you'd like. I used a chunk of research into the area when preparing a workshop last year on why stress management needs more attention in business. In terms of directly linked stress issues that can actually be measured, work related stress accounts for losses to developed economies of approximately 2.1-3.6% of GDP. Why add to that figure by not taking 30 minutes away from your desk to unwind at lunch?
If HR guys like me can save big chunks of money I'm all for it :) Stress related work absences cost the US Economy $300 BILLION a year.
I'd be willing to bet most of that stress comes from low wages and high expectations of employees...USA for ya.
Problem i have with the 30mins lunch break is if i drive to subway to get lunch, by the time i get back it's 28mins gone, takes, so naturally im eating at my desk anyway, and i wouldn't call those 28mins i spent driving to subway and waiting for food "relaxation".
But it certainly is nice to be uncontactable for 30mins at that time.
That would mean I have to socialize with other humans
I might have some footage from start of year boz
Unicorn washed. I am going to need to paint it in the next 12 months of I keep it. The white is falling off all over the place revealing the gun metal goodness below.
Custom gunmetal flecks? :P
Pretty much. Who ever did it did a shit job. The gun metal is still all shiny.
Bought a reconditioned CAS from USA it arrived today :D
Went to work sick rather than having day off cause I wouldn't be resting at home.
Also A/C tensioner bearing turned up :D
Good stuff. ..CAS's are the devil!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
