Mugabetown - Whoretownin' At It's Worst.
once you get beyond 30 Bunts its all down hill mate.
Oh noes!
Cause my auto destroys all the cog swapping monkeys, why would I want to put something in that makes the car slower...
This is true, you really cant afford to be any slower.
exactly....when they got rid of 1c and 2c pieces we had to round up!
Rounding down does not apply to Nick though. so to do a 13 he will have to do a 13 flat
but it doesnt tho. does it........ your fully manualised auto. your losing more power than you would with a manual firtted with rip shift.
yea if you where pushing out 6-700 hp for the drags auto would be best....
this is why Paul should be a real Mexican... He can have both!
He needs a TT kit for that HSV of his!
i do. but it cost too much. one day.
10 grands worth of overnight parts from usa.
just in time for whorewars.
should never blend in you should stand out
Lol yeah I try not to stand out these days! Most of the time...
You guys must be stealthy! I was at the Jimmy dinner too and thought I had a good memory, but I have no recollection of you. My world is now turned upside down because I thought I was all over this remembering shit thing. lol
Yeah, Ninjas! We were sitting to the right of where the "stage" was near the bar :)
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
