Mugabetown - Whoretownin' At It's Worst.
I'm at work, work is boring and through photosynthesis I am boring as well....
I am not convinced that is the correct use of photosynthesis.
I don't think think using radiant energy to turn carbon dioxide and water into carbohydrate is the cause of your being boring. Though according to Ants you are green so maybe you do photosynthesise
I hate everyone having breakfast and days off... Stupid me even said yeah no worries I will do a full day Saturday before working Saturday night at my other job, that's what I get for agreeing to shit when I am having a good day!
LOLZ
4th fishies down the freeway! ensure to upload vid for lolz
2nd half throttle slide off a round about and up the street (couldn't hit the hammer due to traffic) he went very quiet
What are u on about, photosynthesis is the process of photographing synthesisers in your spare time.
How could you not know that, youre a sound engineer you deal with this stuff every day... And twice on weekends when you photograph your German folk band zeig mir die Müsik
  • Like 1
bahahahahahahahha!
Quick snap shot from Zeig Mir Die Müsiks last gig they played at keine krähte hier arena in woodford, not bunts well developed beard (it's a fake of course but no one needs to know he can't grow facial hair)
I spoke to Sean this morning.
The Ant-Eater went back on the dyno - everything going well
An hour after being on the dyno - Hatlech decides to shit itself
:( aww not good bro
Alledgedly everything is still running but the USB port slows down and Sean cant get any proper reading from it.
Haltech was sent back to Sydney yesterday (hopefully will get it soon) to have a look at it.
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
