Mugabetown - Whoretownin' At It's Worst.
Just no, Sean did not manage his workload well coming into two major events but he would not send an ECU back to Haltech to buy himself time.
More accurately, telling the customer he has sent the ecu back to haltec when in fact the ecu is still in the car ;)
Yes, are you sure you want to accuse a business of somthing that you have no real information on?
A call to Haltech would clear the whole thing up, In fact, Ants if you are reading do call Haltech and make sure they dont drill a big hole in your ECU, they have form in that regard.
FOOOD!!!!!
Early lunch, was dying, needed food... 18hrs with no food is way too long!!! (Ate dinner with a friend with kids last night so it was like 5:30pm)
On the plus, fed so mood has improved yayyyy
I never accused a business of anything, just reading between the lines...
I have absolutely nothing against Sean and or Whitey (if he is still a part of EFI or whatever they turned/merged into???), they have always been very helpful to me and I continue to recommend Sean as a tuner where applicable.
FOOOD!!!!!
Eat a snickers. You aren't yourself when you are hungry
Pretty much! I get Hangry for sure!
You know those hungry screaming children at the supermarket, I am like those but taller and more offensive language depending on the level of hunger and where you shop...
i think you should marry me!
If they have always been helpful what leads you to beleive they would do what you claim they have done
bs been working...
Legit, I was doing staff development forms and shit.
Yes...they like them some drilling
FOOOD!!!!!
Were you Hangry? (hunger induced anger)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
