Mugabetown - Whoretownin' At It's Worst.
thanks bro. that means a lot. I was really lookin forward to getting my car back. Finally seeing it on the Dyno last week was really exciting. Now it just feels Im getting shatterred all the time.
if you need it no probs man as i said my car is of the road and my business is main priority now so you can use if you need
Anyone know how to remove gel nail polish? It's the shit that is cured under the UV lights...
Soak cotton wool in nail polish remover and press onto the finger nail and sticky tape it on there for an 1/2 and hour, take off tape and wool and run with a Brillo pad or semi abrasive cloth.
Hand buff nails and apply French tips cause they look cute and classy and easy to remove ;)
nick join the rockstar social club mate. look for a skylinesaustralia crew.... its for gta.
let me just check in my handbag...
At least you have a handbag, I don't!
Winning! Usually stuff just peels off my nails within a few days, 3 weeks later it's still stuck on and shitting me to the max!!!
p.s. Thanks!
I actually know the answer to this, soak in acetone for about half an hour and they fall right off, Anna does this all the time!
Unless it is pink and sparkly I am seriously one of the shittest girls ever lol...
...the cock, it may have been in and around your mouth hole
Ah ok man my home Internet is down ATM and will be for like a month :(
Refer to above it may speed the repair up
I found an old bottle of ma blaurk nail poilish from back in the day a couple weeks back, made me ltm
Need to remove this from your brain with an intense marathon of beer, cars, Porn and football.
Anna is a bit the same, though due to her career knows lots of beauty/makeup stuff, aside from that, loves hello kitty, also rebuilds engines lol
It cant be removed, half of my house is a makeup salon, Anna works at a makeup supplier, brides come to our house to discuss makeup, half of Annas friends are in the business. ITs here to stay, but it makes Anna happy and makes us money so I am all good
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
