Mugabetown - Whoretownin' At It's Worst.
thanks bro. that means a lot. I was really lookin forward to getting my car back. Finally seeing it on the Dyno last week was really exciting. Now it just feels Im getting shatterred all the time.
if you need it no probs man as i said my car is of the road and my business is main priority now so you can use if you need
Anyone know how to remove gel nail polish? It's the shit that is cured under the UV lights...
Soak cotton wool in nail polish remover and press onto the finger nail and sticky tape it on there for an 1/2 and hour, take off tape and wool and run with a Brillo pad or semi abrasive cloth.
Hand buff nails and apply French tips cause they look cute and classy and easy to remove ;)
nick join the rockstar social club mate. look for a skylinesaustralia crew.... its for gta.
let me just check in my handbag...
At least you have a handbag, I don't!
Winning! Usually stuff just peels off my nails within a few days, 3 weeks later it's still stuck on and shitting me to the max!!!
p.s. Thanks!
I actually know the answer to this, soak in acetone for about half an hour and they fall right off, Anna does this all the time!
Unless it is pink and sparkly I am seriously one of the shittest girls ever lol...
...the cock, it may have been in and around your mouth hole
Ah ok man my home Internet is down ATM and will be for like a month :(
Refer to above it may speed the repair up
I found an old bottle of ma blaurk nail poilish from back in the day a couple weeks back, made me ltm
Need to remove this from your brain with an intense marathon of beer, cars, Porn and football.
Anna is a bit the same, though due to her career knows lots of beauty/makeup stuff, aside from that, loves hello kitty, also rebuilds engines lol
It cant be removed, half of my house is a makeup salon, Anna works at a makeup supplier, brides come to our house to discuss makeup, half of Annas friends are in the business. ITs here to stay, but it makes Anna happy and makes us money so I am all good
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
