Mugabetown - Whoretownin' At It's Worst.
thanks bro. that means a lot. I was really lookin forward to getting my car back. Finally seeing it on the Dyno last week was really exciting. Now it just feels Im getting shatterred all the time.
if you need it no probs man as i said my car is of the road and my business is main priority now so you can use if you need
Anyone know how to remove gel nail polish? It's the shit that is cured under the UV lights...
Soak cotton wool in nail polish remover and press onto the finger nail and sticky tape it on there for an 1/2 and hour, take off tape and wool and run with a Brillo pad or semi abrasive cloth.
Hand buff nails and apply French tips cause they look cute and classy and easy to remove ;)
nick join the rockstar social club mate. look for a skylinesaustralia crew.... its for gta.
let me just check in my handbag...
At least you have a handbag, I don't!
Winning! Usually stuff just peels off my nails within a few days, 3 weeks later it's still stuck on and shitting me to the max!!!
p.s. Thanks!
I actually know the answer to this, soak in acetone for about half an hour and they fall right off, Anna does this all the time!
Unless it is pink and sparkly I am seriously one of the shittest girls ever lol...
...the cock, it may have been in and around your mouth hole
Ah ok man my home Internet is down ATM and will be for like a month :(
Refer to above it may speed the repair up
I found an old bottle of ma blaurk nail poilish from back in the day a couple weeks back, made me ltm
Need to remove this from your brain with an intense marathon of beer, cars, Porn and football.
Anna is a bit the same, though due to her career knows lots of beauty/makeup stuff, aside from that, loves hello kitty, also rebuilds engines lol
It cant be removed, half of my house is a makeup salon, Anna works at a makeup supplier, brides come to our house to discuss makeup, half of Annas friends are in the business. ITs here to stay, but it makes Anna happy and makes us money so I am all good
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
