Mugabetown - Whoretownin' At It's Worst.
hahaha take a number and get in line, Heaps of people want in on what I do...There is a serious lineup to get into my field.
What IT experience do you have Matt?
a fair bit across varied areas.
Haven't played with Windows Servers myself since the 03 version.
Lots of level 1 work on fixing desktops and printers
Can strip an rebuild laptops.
Old work had me build one of there Linux servers. After them having it 18 months and never getting it into production I had it up and running and through testing within 6 months (very strict testing they wanted especially after their f**kups). I actually hear that the system ran for 5.5 years without a single fault, they just replaced it as a preventative measure.
I used to be able to hack code together in java, specifically for HMI displays that talked to PLCs to run part of a steel works.
I use to be able to code well in C, haven't touched it in 5 years though, can read it, but don't know it fluently any more.
And I do a bit of hacking together with PHP and mySQL as a past time.
Have my own ML350 server at home, doing a fresh load on it at the moment as my acquisition centre, and file server.
As for work, I just talk it up... I'm a consultant, primarily dealing in SMB. Haven't actually touched the tools professionally for about 3.5 years. Have done plenty for myself and others but not as a job.
Just spoke to Haltech. They have not received any ECU from EFI Performance or under the name of Sean Ramsdell.
I asked them about the drilling of holes in ECU and they told me that they only do that to demonstration / display versions for dealer workshops to ensure they are not used again in the event they are stolen.
He ensured me that they will not do that to mine (if its there)
Really, really, really, really depressed with everything regarding the car FTM.............................to the point where I feel it just wasnt mean to be :/ :/ :/
The worse part about it is if the Haltech is fked, Im not in a financial position to purchase another which means no car, no tuning................................nothing.
Charity Cruise for Ants' Ecu, Tony's turbo, Chants' new car?
Anna is a bit the same, though due to her career knows lots of beauty/makeup stuff, aside from that, loves hello kitty, also rebuilds engines lol
We could be friends... I however know shit all about makeup or beauty, I hate going to the hairdresser with a passion!
It cant be removed, half of my house is a makeup salon, Anna works at a makeup supplier, brides come to our house to discuss makeup, half of Annas friends are in the business. ITs here to stay, but it makes Anna happy and makes us money so I am all good
This could come in handy information in the future!
Happy Wife Happy Life.
Ah so are you doing pre sales work or in out money grab without being on the hook for delivery of product?
Charity Cruise for Ants' Ecu & Chants' new car?
FYP
Why no turbo for the Maxima?
Because Maxima, we will however chip in for Presidential flags
Ants, really sucks to hear your position mate. If you need anything...I mean anything, let me know. More than happy to help....sacrifice a testicle.
FYP
FYP
i do from opportunity arising, to the point order is placed, at which point acquisition of goods is handed to another department.
I then run hand over to technical and they manage install.
Ants, really sucks to hear your position mate. If you need (almost) anything, let me know. More than happy to help..
Thanks mate.
One thing awesome about this place is the goodness of people which is really appreciated.
Im just depressed for now. I will get over it.
I have a sneaking suspicion that the ECU is not Fkd. but just requires a firmwarre update which I found here as Sean mentioned it is a v1
http://www.haltech.com/downloads-2/ecu-software-firmware/
I will talk to Sean next week and see if he has seen this, as to send a new working ECU back to Haltech for repair may not had been necessary but I will verify this wtih him.
Anna also hates the hair dresser lol
If you ever have make up needs let me know and I will pass it on to Anna
Thanks mate.
If the communication to the ECU is fokked though Sean wont be able to upgrade the firmware insitu
Anyone know how to remove gel nail polish? It's the shit that is cured under the UV lights...
I was gonna suggest industrial paint stripper but then I came to my senses :P
Maybe. I do not know enough about it comment on the inherent issue. Best to wait to hear from Haltech and Sean.
Probably EFI maybe allstar
ok.
Pre Sales then, I used to do it and will probably start my own company again to do it in this space.
AllStar all the way.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
