Mugabetown - Whoretownin' At It's Worst.
It's not that I struggle with it (usually make it my bitch), I spend the basically all day every day in it, it just pisses me off when it won't do what I tell it.
Seriously powerful tool. Wish I could do sumproducts properly tho lol
=SUM(A2:D2)
Easy.
Family is so over rated...anyone want to buy a brother, 88 model, been around the block a few times but low k's. can lift heavy objects and has sens of humour - $2 ono
farkin Lulz
Yeah mr ants same deal, I'm not very helpful on the computer side but I can help pull apart/move heavy things :)
(And supply beer, I'm good at that)
thanks dude *nun-chucks noise*
F1.
Never used sum product, seems simple, what do you use it for specifically in your job?
And now that I've looked at it, I know we're to use it in my job... Lol
F1.
get back to work Marie
We need little stickers of our cars names with illustrations lol
Little boat for Chantelle
Mushroom cloud/missile for me
Anyt eater for Anthony
Hooker for mike
Unicorn for bunta
Whale for tom
Steaming pile of crap/maxima badge for Tonys :P
We need little stickers of our cars names with illustrations lolLittle boat for ChantelleMushroom cloud/missile for meAnyt eater for AnthonyHooker for mikeUnicorn for buntaWhale for tomSteaming pile of crap/maxima badge for Tonys :P
not a bad idea brah.
Will think ova few tonight
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
