Mugabetown - Whoretownin' At It's Worst.
We need little stickers of our cars names with illustrations lol
Little boat for Chantelle
Mushroom cloud/missile for me
Anyt eater for Anthony
Hooker for mike
Unicorn for bunta
Whale for tom
Steaming pile of crap/maxima badge for Tonys :P
ok so for Nick I have this
Or this
198720_10151191472652766_1736580438_n_zp
for Tony
robert_mugabe_funny_round_sticker-rb91e1
or this
F1.
Never used sum product, seems simple, what do you use it for specifically in your job?
And now that I've looked at it, I know we're to use it in my job... Lol
Analysis on massive ranges of data to sort and summarise various stuff. I am a project controls consultant. About 1500 projects totalling a smidge under $7b in this portfolio.
and here at my work we are happy with a project that sells for $20K... Lol
You deal with gumbyment?
I actually have withdrawals when not on here now... Not because I am a post whore (arguable I know) but because I don't want to read through pages and pages to catch up...
I know, come to a sprint day and race me.
Refer to post in argument thread, I have no interest in smashing my car and will only ever push to about 7/10 of its capabilities because if I prang it I'm throwing 20g out the window and I don't want that for a bit of online gloating.
Smart statement, I endorse this
Refer to argument thread, you drag your car and thus risk smashing it into a wall and throwing 20g out the window for a bit of online gloating.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
