Mugabetown - Whoretownin' At It's Worst.
I have seen with my own 2 eyes a stock one do a 13.2 something and one with a decent clutch and a ECU do well into the 12s.
Those times are....not good. And knowing Chris in particular the launch would have been a softie.
Oh I know it can be done... What I'm implying is that anyone with half a mind wouldn't do it to their car.
They could do a 6 second pass, won't change the fact that I broke 2 of them and think they're weak as piss droney horrible sounding boost fed midget motors
How do you break a N/A 25? You are menat to use oil not sand! How many times must I tell you!
  • Like 1
ls1 shits on rb25. just saying. ive had both.
no idea how or why they are being compared.
but i was an import guy since i could drive. (15 years) first manual ls1 i drove i bought. sold 33.
200kw rb vs 225kw ls1.
ls1 was much more fun to drive.
awaits butthurt, flames, and accusations of being a nick sympathiser!
We thought people with half minds wouldn't put a LS in their skyline either...but here we are! :P
If you aren't launching a GTR hard (near the limiter) dont bother, they are not a fast car off the mark unless you launch hell out of it
Fastest unopened, standard injector ls1 is?
Fastest unopened, standard injector rb is?
Fastest unopened, standard injector vg is? 11.76 @117.91
Who cares don't be a scab and change ur injectors lol.
In saying that depending on what u class as unopened there are LOTS of cam only ls1s into the 11s
I stopped listening after here, I saw something about hell.... Do u want to repent your sins Andrew come on, repent embrace, love
Unopened is unopened ;)
Stock turbo also ;) Why change injectors when stock can net 11's? haha
Dirt Garage ran an 11.8 unopened and with stock injectors, thats just off the top of my head
now is not the time to repent, I will only have to do it again later
So what ur saying is, it's ok for your motor to change something to allow much more air into the engine but it's not ok in my case.... Hmm
Yer but the sooner the better u try repenting all your sins when your 90, you'll be repenting for shit you didn't even do.... "I'm sorry for digging up the lawn.... Oh that I was the dog, I hated that dog I distinctly remember the day I got him a Sunday I believe or was it no no it was a Wednesday cause it was the same week as aunt Betsy, or was it carols birthday, aunt carol was such a nice old.... Old, old? Old spice I love the smell of that. Wait what was I talking about"
See how we will run into an issue, repent now while u can
Just be happy that you have the fastest auto Ls1 R33 that is black and orange/red owned by a guy called Nick from a town called Gatton.
thats the thing about repenting, doesn't matter if you did it or not, all is forgiven.
No.... If u haven't noticed I'm never happy unless I'm annoying someone else
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
