Mugabetown - Whoretownin' At It's Worst.
Plates have changed since last time it happend just FYI
Getting to seem like it, I have a perfectly clean driving record don't even have any parking fines even my dad and some of his friends think it's ridiculous and they were cops when I was growing up.
Your car is pink right? It would stand out a lot. I expect this pulling over thing will be very regular
Where did you go!?
There was a second universe the exact same as ours but it was different. And I got stuck in the second earth. Couldn't get back, and it affected our earth, causing flooding and rain.
Trippy dream right there. I have a new novel idea now :D yay
They go through phases, earlier this year pulled over 10 times in 9 weeks, then nothing since about April and now again 3 times this week. Before that maybe 5 times whilst I have had my licence (including on P plates in Pinky) and it has always been pink in the 7 years I have owned it. I used to get pulled over more on my scooter than in the car.
Yeah, and people think I am a tripper watching Charlie the Unicorn lol....
But seriousl wtf did you watch before you went to sleep last night haha!
I watched wonderland. This is the only dream I've ever finished awake. It envolved sau people to :/ that makes it weird haha
LOL! Awkward...
Last dream I had that I remember was meeting webber, at a beach... It was after watching an F1 race and the same night Zane had a dream he met webber but at the track lol which is why I asked what you watched before it haha
already a film....
Does This only happen when you watch Dr Who before bedtime :)
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
