Mugabetown - Whoretownin' At It's Worst.
Morning all
I imagine he starts work obscenely early tomorrow.
Bingo, up at 4:45
Engineer me thinks
Yep
bet ya he's on da big bucks. And he's smart enough to invest it rather than spend it.
I'm saving the lions share, but that's not to say i'm living like a monk either.
Investing the savings, on the other hand, needs more work
Soooo much progress for the charity cruise last night. All will be released on Wednesday. My rad hurts from progressing so far. :(
Good to hear!
Now just make sure you run it during my RnR...
I submitted QLD registration form, but haven't received a response email with pymt details.
Is this usual, or should I complete another?
Just checked google drive and your application is there. Were currently going through a change in the membership secretary role and Martin (the old guy) has been pretty flat out.
Someone will contact you shortly.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Morning Pete! 8 December for charity cruise mate. Got a pretty great route organised.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Hi Pete, what type of engineering work?
Thanks for following this up :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
