Mugabetown - Whoretownin' At It's Worst.
Was a love tackle, Chris picked me up off the ground and then I went to lift him up but was way to pissed (had literally drank a bottle of scotch) and it kinda tuned into a suplex into the bin and cans and Chris landing on top of me lol
Lol just lol
We had been drinking since 10:30 am and was around midnight when this happened. He tried to be a mini hulk and bear hug me and lift me up ( I am 6ft 4 roughly and 100+ kgs) and he failed miserably and ended up tackling me into the bin. This all happened a month after I had surgery on both of my feet as well
That is too funny lol (with exception of feet)
single cam 30? Pass
How much is the other one going for now Col and Pete? Beause the price as of May was optimistic to say the least!
Dunno about the white one,I've always been after a blue one though which is why it caught my eye, just 2 days after I left Brisbane. Benno seems to know something about it so now om intrigued though
Ahh i see, the blue one has been around a good while, Spilmer owned it before Ian.
Link to Ians sale?
Edited by Bunta
Not bad at all, all it needs is a rebuild and probably a different computer.
But do contact Benno, I think there is some accident history there somewhere?!
Edited by Bunta
shh, I was hoping I'd be able to go take a look at that one once on off swing..
Shieet son. Better hurry up then :-P
Link me to the white one somebody!
On gumtree not listed on carsales. On phone so cbf with links.
Blue 17k. Sounds like a steal. I know Spilmer was very particular dont know how its been treated since.
White one is at 25k. Will need to look at it in the flesh to make a decision but I know he spent more than that on it with the motor and other go fast bits.
+ it has most of the gear ready to swap out the 35r and put in a new precision or efr turbo
yeah, go buy the white one! :P
In your opinion (or anyone elses), is a motor at that sort of age making that sort of power a ticking timebomb, or just something you'd want to do one day soonish? or am I misreading the ad and the engine itself is actually cactus already?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
