Mugabetown - Whoretownin' At It's Worst.
Blue 17k. Sounds like a steal. I know Spilmer was very particular dont know how its been treated since.
White one is at 25k. Will need to look at it in the flesh to make a decision but I know he spent more than that on it with the motor and other go fast bits.
+ it has most of the gear ready to swap out the 35r and put in a new precision or efr turbo
Seems like a lot.
yeah, go buy the white one! :P
In your opinion (or anyone elses), is a motor at that sort of age making that sort of power a ticking timebomb, or just something you'd want to do one day soonish? or am I misreading the ad and the engine itself is actually cactus already?
I wouldn't be confident in it lasting any significant amount of time, especially with the Power FC in control
I don't get the pfc hate? I mean they're an old design and don't have the features of newer designs, but is there something intrinsically wrong with them aswell?
There is something intrinsically wrong with the design of the RB engine, which is calculating crank position based on cam position, this leads to unstable timing signals. Having a power fc does not allow you to do away with the CAS and fix the issue.
Also it has no knock control, so combined with the timing jitter you engine doesn't stand much of a chance in the long term.
Edited by Bunta
The hate is justified in this one.
m800 ftmfw... Just saying :D
Sean agrees with you, but also says the performance gap between a Motec and a Wolf/haltech/link/vipec is now next to nothing so the extra expense is no longer justified.
Currently googling new wheel combos for the 33. Dont know whether to stick with black rims or move onto white.. Also looking at some 16's i can fit bigger tyres on
drags?
15's will fit with some small caliper mods i heard?
When do we get promoted from car club friends to real friends?
I'm gonna say when you've achieved one of the following:
I've slept/passed out on your floor/with you on the floor lol
I've shirts off man hugged you
You've received >5 drunken phone calls from me
Probley other reasons but those spring to mind
not sure if i have done the over 5 phone calls.
This is true. 6 years ago was the dogs bollocks!
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
