Mugabetown - Whoretownin' At It's Worst.
This explains the eyeliner removal tip lol
Well yer, I've got a big framed picture on my wall in the band room with full blown hair make up 80s rock god mode from a gig we played. People walk in and are like "wtf were u thinking" and I usually think "who cares it was tons of fun and I bet you wouldn't have the balls to wear it in front of 50~1000 people so shudup " lol
i still want to know the secrets of these natro stages.
Step 2 is being completed either tomorrow/Saturday/Sunday....
Step 3 within the next monthish, step three is a fair bit of coin... Step 4 is the one that really hurts though :/
and then they think, "no, i just wouldnt want to wear it in the first place, let alone infront of 1000 people"
Lies, if I could get away with it I'd rock eyeliner everyday ... But alas, I'd probley be fired and not allowed into anywhere lol
Can i start calling you gay boy nick? Haha
And morning all
Depends how you like your face arranged? :)
Anyhow, cold morning is cold and apparently of you don't check your water levels on your dirty falcoon they get hot when your driving to work lol
yes chants we can look after the ant-eater while ants is busy with child :) we wont hurt it :whistling:
Gawd no. I can just hear you all whispering about which mointain to take it over first.
We are a very large sometimes deranged family here at SAU, I know that if any of our members were in need we'd have 5 plus people offering to help
ok then 2 handy shandys in my reachbank
tre if you come up here and drink with the qld whores you are in the currency
Cos we all know that SAU QLD can drink...a lot.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
