Mugabetown - Whoretownin' At It's Worst.
Haha go to buy some hmmm... Do you have any more of this out back I need to fill a bath with it...
Sales person... Ahhhh WTF...
Noooooo.... sales person: We'll arrange for a personal guided tour of the factory for you and complimentary mixing vat pool pass rofl
True they go a long way for a sale lol
Surprisingly there is another brand of that stuff that does get sold by the 44gallon drum.
Known in industry as just "Barrier Cream"
The electricians at my old job introduced me to it, I also worked with a bunch of fitters. The fitters called the electricians poofs for using "hand cream"...
Yeah, one of the fitters finally tried it... Now the fitters are also being a bunch of poofs and using hand cream... LOL Stuff is magic for protecting your hands from grease and grime. Should get my step dad to get me some for while I'm working on cars... Although, I've also been abused into wearing gloves so I dont cut myself as much... LOL
Barrier cream - that takes me back. This stuff above is supposed to be all natural. I use mainly vinyl gloves these days KBS have some awesome ones and so do Hercules (Nitrile). Anytime hot engine bay Mechanix gloves straight on, so sick of getting burnt when adjusting/checking
I don't care what anyone says, anything that is "man made" is still natural.
It's what happens naturally when you compress/heat/cool/aerate/mix certain chemicals. These things just happen... Just because we give them the ability to happen doesn't mean it's not natural.
Just like electricity flowing through a resistor in a vacuum emits light... This is natural... Nature and physics allow it to happen :P
By natural I mean lacking carcinogenic chemicals, but yes they exist therefore they are natural lol
but there is a distinct difference between something natural and artificial Marie
Immy out hours ago. Every time she sees me on computer, she tries to play pokies with the keyboard. go daycare you good thing :)
i was referring to LukeGTR. But my daughters were lights out an hour ago now
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
