Mugabetown - Whoretownin' At It's Worst.
My goals at the moment are a fully paid off house in 10 years time...
And if it's not paid off, It's because I've bought a second one.
if u are able to achieve that Marie, I will somehow find a way to marry u and become your trophy hubby
If my requests that I made at work are met in some way, it's actually 100% possible on my own to pay off my debt, save a deposit, and pay off a house all in a 8 year window.
Please note, I'm not aiming like so many of my friends to borrow to my absolute maximum and live in the most ritsy suburb like most of the people I know, who are all up struggle street and causing endless arguments with their partners. I'm looking to do it the smart way.
Buy a house in the $350K or less bracket, with a 20% deposit.
Yes, it will take some hard yards, yes it will mean not being able to mod my cars left right and centre, but 10 years from now, I'll have a disposable income.
But then again, my goal set may drastically change. LOL, but this is the current goal I'm currently working to, and I'm already clearing my debts with a higher repayment than what it will cost me to pay off a $500 000 loan in 30 years ;)
im looking to do it differently.
similar price bracket, but near on 50% deposit, because smaller loan means less interest to the bank.
Offset account also does this while leaving you with liquid funds in case of emergency or unicor being purchasable at the right price
sounds very positive mate. Theses days if u are able to be disciplined and save / make greater repayments towards existing loans, you can extinguish home loans within half the normal time.
Your last paragraph is probably the most realistic one as things will always change with some causing goals to also be changed. Whether they are positive or adverse in nature.......only you will know
but if the money is easily spendable, i may just spend it. easier if i cant touch it as easily.
It had flecks of what seems to be black tyre rubber/compound all over it and was pretty dirty. I am convinced its last outing involved two rear shredded tyres lol
by whom ;) ?
Debt shop. Move money around to lowest possible repayment figures. 0% credit cards and don't borrow anymore for a while. It reduces debt levels and increases good repayment history. Serviceable debt isn't the enemy, it's just people never plan for things like: what if I lost my job tomorrow.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
