Mugabetown - Whoretownin' At It's Worst.
real keen to see the ant eater on the weekend :) are you totally in love with it? driven it much?
not too much.....think I did about a 100km since I got it back...........but yes it's great to finally have it.
Need to learn how to drive it all over again..........but jut feels fantastic Bodo :)
good to hear man, guess you'll be takin it easy at the laps of happyness?
well I'm not gonna ring it's neck that's for sure.
Will be taking it sensibly until I get my confidence back up................which is gonna take quiet some time
But I will get there in the end ;)
north side. just watching Scotts build, and hearing that Dan is building Matt's new engine
morning scott hows the car?
Still at All Star Tuning. Long story short is there is a few hiccups here and there with the transplant. Nothing major just little things here and there that need modifying as they foul on other parts etc. Heaps of little niggly things like that.
Last i heard was the E85 was eating away at hte fuel line a little so once thats fixed its ready to Dyno. Its full of water and oil and just needs the leaky line fixed.
I'm just throwing it out there, Colin, Beezlebub89, is a f**king legend! :D
Gidday Tony ma man.
Mine either!
Mine is... Now I am the odd one out...
Changing my pic won't help that tho...
Hello Mell :action-smiley-069:
Did I warn you of the little bits and pieces that just need a little work like I did zac? Having done it they are a dint as it's all little bits and pieces, none of which are particularly difficult to fix but take time and sometimes thing have to be taken back off to sort them.
There is a reason the evo is only going 2.3L and not the different block 2.4 route.
I always knew it was never going to be a simple change over. Im not worried/fazed at all that its taking a few weeks longer with these little things. Id rather it all be done right the first time.
  • Like 1
Hosting the biggest Amateur event in QLD at the moment and all these good young golfers think they are Tiger Wood or Adam Scott.. Hurts my head
Tell them their swing is awful Scottie and that they need to put more hip into it...........................for the lulz :P
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
